How to remove the prusa bear mod
- I have just foolishly bought a MK3s+ which has had the bear mod done to it. After further research I have found out the bear mod needs custom firmware and it is no longer supported. How can I salvage this is there a way to undo the mod without costing a lot of money.
https://www.facebook.com/share/16VappYfsG/
Publié : 27/05/2025 3:46 pm
RE: How to remove the prusa bear mod
Update the firmware with Bear-specific changes. I've done the same and it's quite trivial.
You could also opt to run the Bear firmware for calibration only, and from then on running the latest stock firmware only.
Publié : 08/06/2025 8:36 am
