Extruded Frame self locking cam mount
Printed these up to help in mounting to the extruded frame.
They just slide in and when you turn them to the right to tighten the screw, they cam into place and hold to allow you to finish screwing it down.
Re: Extruded Frame self locking cam mount
Great helpful clip to use. Thanks for sharing!
I am considering adding some frame support gussets. These will make the install much easier.
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Thanks.
I printed them up for another mod but I think I'll use them for adding a camera mount too.
Thanks.
Is this different than what I released (see my btw comment)? https://www.thingiverse.com/thing:2805753
I had not seen that, but it does look similar.
This one I made as just a generic mount, but it has a notch on opposing sides to lock itself into the extrusion instead of spinning around.
didn't notice that. smart.
