Constant disconnects over USB
Matto
(@matto)
I have a 2 week old Prusa MK3S+ and I am using with a Raspberry Pi 3 running OctoPrint.  This OctoPrint server has been running rather continuously since March 2020 on another printer with zero issues (same hardware).  When I connect it to the MK3S it works for a time, then eventually loses the USB connection.  I then lose that functionality for a time, as if I reconnect the USB it forces a reset on the MK3S.  Any thoughts as to what the issue could be here?  I'm not sure if there is some known aspect to the MK3S that I am missing as it relates to OctoPrint connections.
Thank you'
 -Matt
Stock Prusa MK3S+ built from kit on 12/2020
OctoPrint, typically print from a drybox, no enclosure yet
Printing proudly since 2011
Opublikowany : 01/01/2021 12:36 pm
RE: Constant disconnects over USB
Does this help?
https://community.octoprint.org/t/octoprint-keeps-running-into-communication-errors-and-timeouts/227
Joan
Opublikowany : 01/01/2021 1:26 pm
Matto
(@matto)
@joantabb
Thank you, that helps a lot.  I searched for a while and did not find that thread.
I'll try both switching Pi's (I think I have a Pi 4 Model B sitting idle) and increasing those timeout settings.
Thanks,
 -Matt
Opublikowany : 01/01/2021 1:38 pm
Matto
(@matto)
A little early to declare victory, but after 1 hour the RPI4 is working MUCH MUCH better than the RPI3.  I would have had 3-5 disconnects by this point.  Same SD card.
 -Matt
Opublikowany : 01/01/2021 5:43 pm
Matto
(@matto)
Ok, its  been printing like a champ for about 8 hours yesterday and a few hours this morning.  Switching from the RPI 3B (not plus) to an RPI 4 seems to have solved the issue.   Zero changes to any other hardware or settings, exact same SD Card.  Exactly as described by "Brent_Dowell" in the first comment on the linked post above.  Easiest fix of a tech issue in a while. 🙂
 -Matt
Opublikowany : 02/01/2021 12:44 pm
