Building guide for printer enclosure, with parametric design.
Hi
I just published a simple guide on how to build a heavy and solid enclosure, originally for the Prusa i3 MK3S printer. The final enclosure can look like this:
All you need are wood boards (plywood or particle boards), woodscrews and the usual tools to join two boards in a right angle. At the sides, I use 5mm acrylic glass panels. My guide contains a parametric Fusion 360 design, you can adjust to different wood types and your desired platform height, width and depth.
Read the full article for all details:
https://luckyresistor.me/2020/09/01/build-a-3d-printer-enclosure/
Have fun!
Lucky Resistor
Opublikowany : 02/09/2020 11:43 am
