Bondtech emits clicking/squeaking sound when retracting filament during print
AmishTechSupt.
(@amishtechsupt)
Following a Bondtech upgrade on my MK3s, it has begun to emit a slight click (squeak when listened to closely) when the extruder retracts the filament during prints.  I've adjusted the 2-4 turns that Bondtech suggests on the idler screw, but the sound remains.  are there other parts that need attention (loosen / tighten)?
Thanks in advance.
Opublikowany : 18/05/2020 1:55 am
PenguinInTheDesert
(@penguininthedesert)
RE: Bondtech emits clicking/squeaking sound when retracting filament during print
I am currently having the same issue after upgrading to the bondtech, did you happen to resolve the issue by chance?
Opublikowany : 07/01/2021 8:13 pm
@shrimply-pibbles
After 2 years, I am having this issue also.  Odd.  Clicks and then stops printing.
Opublikowany : 10/01/2021 4:57 am
evillvi77
(@evillvi77)
I am also having this issue. I believe the motor is bad.
Opublikowany : 14/02/2021 4:15 am
I loosened by X idler/tension screw and mine stopped clicking.
Opublikowany : 14/02/2021 1:14 pm
