Bondtech Direct Drive upgrade
512MB
(@512mb)
Hello!
Would you say that the BondTech extruder is worth it?
I am talking about this one > https://www.bondtech.se/product/prusa-i3-mk3s-extruder-upgrade/
Opublikowany : 17/06/2022 3:18 pm
RE: Bondtech Direct Drive upgrade
I like the design.  Is it worth it?  That is in the eye of the beholder.  I have three installed - two on MK3s and one on a mini. In my opinion, they work better for some filaments to include TPU and flexibles.  They are easier to adjust the tension on drive against the filament.  They will not make a miraculous difference on your print quality and they do require special firmware on the Mk3S.  Worth it/. To me yes.
Opublikowany : 17/06/2022 3:55 pm
Artur5
(@artur5)
I looked into the Bondtech BMG too, but I ended up purchasing a LGX. More expensive than the BMG but IMHO it's worth the difference in price, specially if coupled with a Mosquito hotend (regular version, not the shortcut).
Opublikowany : 17/06/2022 4:33 pm
ronnie12342003
(@ronnie12342003)
i have had my bondtech nearly 3 years now and its a very good upgrade for me so yes i would say go for it
Opublikowany : 17/06/2022 10:59 pm
I see a lot of folks say it is worth it and cheering people on to install but I have seen very few of the above posters give any substantial reason to upgrade.  I just stopped for the night from a long cross country trip so I am going to offer more meat with the potatoes.
I have three total printers with a version of the BMG - two MK3S and 1 Mini.
Pros:
  • Some report an increase in speed (nominal or minor for me)
  • I find it easier to print flexible.
  • Some report less heat creep - I never had this unless I used the Mosquito hotend.
  • I have noticed more consistency of extrusion and less jam as long as you get the installation perfect.
Cons:
  • Does not offer any significant improvement to print quality
  • The MK3S requires dedicated Bondtech Firmware
Is it worth it?  To me yes, but do not expect the holy grail of print quality.
Opublikowany : 19/06/2022 1:19 am
Do not expect any 'upgrade' to fix basic problems.
First get the printer running optimally; the vanilla printer, if properly setup, works well.  With experience; after at least six months and a few hundred prints, you will have a good idea of which, if any, new features you wish to explore and what physical changes are required to address them.
Opublikowany : 19/06/2022 7:42 am
1 ludzie polubili
