Stopped prints with SImplify 3D
alessandro.d
(@alessandro-d)
Hello guys! I have a problem. I used S3D for slicing and randomly my print stops and a "card inserted" is displayed on the lcd. really I don't know what's the problem with it. I tought it was a power issue and I moved to an ups but nothing changes...
Can you help me?
Veröffentlicht : 07/09/2017 9:33 am
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: Stopped prints with SImplify 3D
Do you use Simplify3D to control your printer or do you print from the SD card?
Veröffentlicht : 07/09/2017 1:41 pm
alessandro.d
(@alessandro-d)
I use SImplify3D to create the gcode and put it on the sd, then I print from the sd
Veröffentlicht : 07/09/2017 1:44 pm
LaPointe
(@lapointe)
Well then it appears that you have an hardware issue somewhere.
Check first the LCD ribbon cable connection on both ends. If everything is Ok, you may have a bad LCD board. You should then contact the support through the chat of the shop.
Veröffentlicht : 07/09/2017 6:49 pm
JeffJordan
(@jeffjordan)
Mitglied Moderator
in my eyes, that's no problem realted to S3D.
when the printer "looses" the sd-card content it's most likely either a bad contact, or a problem with the ribbon cables.
by the way: I don't recommend to use micro-SD cards in combination with an SD-card adapter. this often causes contact problems.
try to get "old" 256 or 512 MByte SD-cards.... they'll do best at our prusa.
if you have the ribbon cables in suspicion, swap them at the lcd 2004 module and at the rambo.
Veröffentlicht : 08/09/2017 2:59 pm
