Slic3r thin wall edge connection
Hi!
how do i get the thin walls connected to the perimeter of the part?
see picture
Re: Slic3r thin wall edge connection
Detect thin walls off in the Print settings, tab Layers and perimeters.
Thomas
this walls only are printed when thin walls is on
this walls only have 0.3mm
and slic3r doesn't recognize them without thin walls
you can also try increasing the infill->perimeter overlap from 25% to 30-35% and see if it helps.
âOne does not simply use a picture as signature on Prusa forumsâ
That is what "detect thin walls" is for. Other ideas:
Make the walls 0.4 or greater?
Fool the slicer and tell it it has a 0.29 nozzle - now it will "see" the walls - but you will need to futz with the flow because it will under extrude thinking the nozzle is thinner?
Really us a 0.25mm nozzle?
