Slic3r thin wall edge connection
Sebastian
(@sebastian-8)
Hi!
how do i get the thin walls connected to the perimeter of the part?
see picture
Veröffentlicht : 14/08/2017 3:02 pm
Knickohr
(@knickohr)
Mitglied Moderator
Re: Slic3r thin wall edge connection
Detect thin walls off in the Print settings, tab Layers and perimeters.
Thomas
Veröffentlicht : 14/08/2017 3:49 pm
Sebastian
(@sebastian-8)
this walls only are printed when thin walls is on
this walls only have 0.3mm
and slic3r doesn't recognize them without thin walls
Veröffentlicht : 14/08/2017 4:33 pm
JuanCholo
(@juancholo)
you can also try increasing the infill->perimeter overlap from 25% to 30-35% and see if it helps.
“One does not simply use a picture as signature on Prusa forums”
Veröffentlicht : 25/08/2017 4:38 pm
AJS
 AJS
(@ajs)
That is what "detect thin walls" is for. Other ideas:
Make the walls 0.4 or greater?
Fool the slicer and tell it it has a 0.29 nozzle - now it will "see" the walls - but you will need to futz with the flow because it will under extrude thinking the nozzle is thinner?
Really us a 0.25mm nozzle?
Veröffentlicht : 26/08/2017 4:54 pm
