Slic3r settings for Prusa MK2S
Hi!
I've download Slic3r Prusa edition but I have poor print, I've Load Config that came with the folder...is this the procedure?
Is there any place that we could see pictures of each tab settings so I could compare my own poor settings?
Thanks.
Postato : 22/04/2017 12:42 am
Re: Slic3r settings for Prusa MK2S
Download this and all must work correctly.
Postato : 23/04/2017 2:57 pm
Hi Pascal,
if everything is installed properly you should see a choice of printers and materials in the top right corner of Slic3r.
Also important note if you have "(modified)" in the Print settings row, it indicates, there are some changes, which can affect your print quality.
Postato : 24/04/2017 2:51 pm
