Slic3r Prusa bug?
I have discovered that the 'cut' functionality in Prusa3D Slic3r 1.33.8 and 1.34 is broken?
If you open an STL file and try and cut it, as soon as you try to move the slider or enter a height value the software hangs?
This works in the version 1.2.9a of Slic3r (the non Prusa version)...
Regards
Chris
Napsal : 06/04/2017 10:57 am
Topic starter
answered:
Re: Slic3r Prusa bug?
Sorry should have said - I am using the Windows 32bit version...
Chris
Napsal : 06/04/2017 10:58 am
Unfurtunately this bug is caused by a 3rd party software library used for the triangulation of the cut. It mostly works on valid models, which do not contain self-intersecting or overlapping bodies, but it crashes on invalid models very often.
I will likely replace the buggy triangulation library with something else one day.
Napsal : 06/04/2017 1:45 pm
