Slic3r - change temperature settings mid print
Koder
(@koder)
Is there a way to change temperature settings mid-print in Slic3r? IE i would like to have bed temperature of 100 at layer 1 and then fall gradually by 1 degree every 100 layers, down to 70'C.
Respondido : 19/06/2017 6:33 pm
shane.t
(@shane-t)
Re: Slic3r - change temperature settings mid print
I searched for quite some time, and the only way to do it seems to be by hacking through the Slic3r generated gcode. Or.... use S3D.
Respondido : 09/07/2017 9:24 am
AJS
 AJS
(@ajs)
I thought you could do this using a modifier mesh. Slic3r's modifier meshes are amazing, but temperature control does not seem to be one of the setting you can change.
http://slic3r.org/blog/modifier-meshes
Note that the latest Slic3r you can "split the model" and not just add your own .stl as a bounding box to change setting in.
But sadly, temperature is not one you can change, so your best bet is to edit the GCODE and add a temperature change at the correct Z value.
Respondido : 11/07/2017 4:12 pm
