Re: Slic3r - change temperature settings mid print
I searched for quite some time, and the only way to do it seems to be by hacking through the Slic3r generated gcode. Or.... use S3D.
I thought you could do this using a modifier mesh. Slic3r's modifier meshes are amazing, but temperature control does not seem to be one of the setting you can change.
http://slic3r.org/blog/modifier-meshes
Note that the latest Slic3r you can "split the model" and not just add your own .stl as a bounding box to change setting in.
But sadly, temperature is not one you can change, so your best bet is to edit the GCODE and add a temperature change at the correct Z value.
