Slic3r and merging close perimeters
gabevan
(@gabevan)
If you try to print the Maker's Muse Tolerance Test v1, there is a section that has a .1mm gap between the cylinder and the main piece. When you use Slic3r to slice it, the cylinder and the main piece are merged. They should be separate objects.
Publié : 08/02/2018 10:20 pm
