prusacontrol time estimates almost always too short? MK3
ben.c5
(@ben-c5)
got my MK3 yesterday, have ran 7 prints so far, didn't really pay attention to the first 5, but the last 2 prints, estimate at 4:22 and 0:38 respectively, but ended up taking 6:30+ and 0:45, which is 49% and 18% longer than estimate. the forum is not allowing me to upload .stl, .prusa, or .gcode files or I would share them for review
anyone else experience this? any fixes?
Veröffentlicht : 10/02/2018 10:23 am
Neolker
(@neolker)
Mitglied
Re: prusacontrol time estimates almost always too short? MK3
Try a new (alpha) version of Slic3r here: https://github.com/prusa3d/Slic3r/releases/tag/version_1.39.1-alpha
It has implemented FW simulator, so the estimated time is very very accurate (<5% error) 😉
Veröffentlicht : 10/02/2018 12:30 pm
ben.c5
(@ben-c5)
I have not used the slic3r yet, just the prusacontrol. on my latest print the estimate was 39 minutes, the actual time was 1:03. so actual print took 61% longer than estimate. file was https://www.thingiverse.com/thing:2758405 . settings were Prusa PLA, 0.2mm, 20% infill, no support, no brim
Veröffentlicht : 11/02/2018 12:32 am
ben.c5
(@ben-c5)
next print
estimate 0:43
actual 1:19
83% extra time
Veröffentlicht : 11/02/2018 4:13 am
Neolker
(@neolker)
Mitglied
OK, I try slice it in Slic3r alpha
There is a GCODE:
Try it again, and you will see 😉
Veröffentlicht : 11/02/2018 2:40 pm
ben.c5
(@ben-c5)
I did switch to slicer prusa edition and found it much better. although it would not slice a lithophane I did. I was able to slice it in prusaControl and just reporting the result
estimate 3:31
actual 5:14
48% incorrect
Veröffentlicht : 12/02/2018 5:13 am
annez
(@annez)
how can you see the time estimate in slic3r?
Veröffentlicht : 14/02/2018 11:29 am
Neolker
(@neolker)
Mitglied
You have to slice it in the latest alpha version from GitHub, then export GCODE and after that you will see these numbers. 😉
Veröffentlicht : 14/02/2018 12:20 pm
annez
(@annez)
ah, great, thank you, that worked.
I did everything except for exporting before.
Veröffentlicht : 14/02/2018 1:15 pm
Neolker
(@neolker)
Mitglied
You are welcome. 😎
The new estimated time is very precise. I have tried it for 5 prints in total and max. error was 3% at very long prints (a few hours).
Veröffentlicht : 14/02/2018 3:12 pm
Mike
 Mike
(@mike-13)
I too would like to see better estimates from Prusa Control software. I do use Slic3r & Cura, but sometimes I do use Prusa Control, and I wish it was a little more precise on the time estimates.
Veröffentlicht : 15/02/2018 6:00 am
Vojtěch Bubník
(@vojtech-bubnik)
Mitglied Admin
The PrusaControl uses the Slic3r as a backend, so it will benefit the new accurate Slic3r time estimate once we release an update of the PrusaControl.
Veröffentlicht : 15/02/2018 8:16 pm
marcos.g
(@marcos-g)
I still haven't seen a print where the time estimates were close to the real print time. For me errors have been always close to the 60-80%.
I'm currently printing a part where prusa control estimates 2h and slic3r (1.39.1 alpha) 2h45. It has passed 2h30 and it still is at 65%, printing in normal mode...
I guess it still needs a lot of work.
Veröffentlicht : 23/02/2018 11:13 pm
