Prusa I3 mk2 clone, endstops software issue
Tom
 Tom
(@tom)
Hi All,
First of all, I do own 2 original Prusa I3 mk2's (one MMU), but I had so many spares laying around that I just had to build a clone.
The clone is with the MK42 heatbed, original frame , a Rambo mini, nema 17 steppers ,an original E3D V6, ...
Almost everything is identical except for the end stops (since I can't seem to find the same end stops anywhere), and a few other things. I also would like to use the firmware from prusa, but the only problem I have from letting it work is the endstops. With the current endstops I bought I can only move my motors to one side and when I plug in the endstops from the original prusa I have it will move to both sides and everything is working perfectly.
The only difference in the endstop I can see is that it uses 3 wires in stead of 2 wires as on the original prusa, so I ordered different end stops with 2 wires but this didn't fix the job.
I'm also no marlin expert, but took a look in it, unfortunately I could not find a section where I could select which kind of end stop the printer has.
Does anyone have any suggestions on the software part on how I can get this to work?
Or... I also wouldn't mind ordering 2 new end stops which are 100% identical than the one Prusa uses. I only couldn't find them, I could try the live chat but don't think they'll offer it I guess.
Thanks in advance,
Tom
Opublikowany : 01/09/2017 3:26 pm
Tom
 Tom
(@tom)
Re: Prusa I3 mk2 clone, endstops software issue
Update:
It seems that nobody has a solution for this?
Anyway I ordered 2 end stops from Prusa for around €6 each, so once they get delivered (tomorrow) I'll do some testing and can hopefully finish the clone.
But if anyone still comes up with a software solution, please do let me know since I'm still very curious.
Tom
Opublikowany : 05/09/2017 11:49 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Most microswitches (like this one: http://www.ebay.co.uk/itm/Medium-Lever-V3-Microswitch-SPDT-16A-Micro-Switch-/262558420165?epid=1380019231&hash=item3d21b38cc5:g:IswAAOSwyWZZXMXD ) have 3 connections. Common, NC (normally closed) and NO (normally open).
You simply remove the lever and connect the two wires to common + whichever of the other two you need (I think - but I may be very wrong - the NC is the one used on this printer).
Plus the Z end-stop which is an inductive probe with +5V, 0V and signal (again normally closed), but it is possible to use a micro switch + servo or a micro switch alone (as in the Mk1) - but you lose the bed levelling features.
Peter
Opublikowany : 05/09/2017 12:57 pm
JeffJordan
(@jeffjordan)
Member Moderator
look inside the Configuration.h:
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
Opublikowany : 06/09/2017 12:00 am
Tom
 Tom
(@tom)
Peter
Thanks that makes sense! I'll test those things out later and let you know.
For the Z end-stop I do use a original MK42 heated bed with a probe, so there I'm more than fine 🙂
Opublikowany : 06/09/2017 6:37 pm
