problem with gcode and temperature
no.a
 no.a
(@no-a)
When i export to gcode, the temp settings are as follows:
M190 S60 ; set bed temperature and wait for it to be reached
M104 S200 ; set temperature
when i use it on my printer, it won't heat the nozzle (but will heat the printbed)
however, if i manually change the gcode to:
M109 S200 ; set temperature
it will work.
how can i instruct slicer to use m109 and not 104?
thanks!!
Opublikowany : 01/09/2017 2:11 pm
AJS
 AJS
(@ajs)
Re: problem with gcode and temperature
You slicer has a section for "Start GCode" This is where you can fix it.
Opublikowany : 01/09/2017 4:07 pm
