Power On always says not calibrated
larry.m
(@larry-m)
Each time the i3 resets it says it is not calibrated, I did and it appears to complete the process,
Respondido : 02/10/2016 5:59 pm
David T.
(@david-t)
Re: Power On always says not calibrated
What i3? Is it MK2? Did you run V2Calibration.gcode a let it run till end?
Respondido : 02/10/2016 6:52 pm
MrMik
(@mrmik)
You need to run/print v2calibration.gcode. It is on the SD card.
Mik
Respondido : 03/10/2016 10:25 am
Shree Kumar
(@shree-kumar)
My experience: If the Live Z adjust value is 0, then the "not calibrated" message is always shows. When you run the V2Calibration gcode, you tweak that value. So the message goes away.
Respondido : 08/10/2016 11:25 am
ayourk
(@ayourk)
I think I saw a recent firmware change on the Github for the firmware to help with this issue.
Dimensions PNG
and an 8 inch (200mm) or greater caliper is recommended.
Respondido : 08/10/2016 11:48 am
Daniel
(@daniel-17)
I will give it a try.
I've experienced the same problem after a failed print.
- Assembled printer running ok for a couple of months
- Petg print stopped manually (from the menu) because the first layer wasn't really satisfing, playing with the z live adjustment
- Printer turned off
- Switched on the next evening, was complaining about printer not calibrated, z index to 0
Do I have to swich back to PLA to run the calibratoin_v2?
Respondido : 20/10/2016 10:48 am
