Octoprint?
PlasticFantastic
(@plasticfantastic)
Octoprint?
Has anyone tried it with the Prusa i3? How good can it get? It does connect at least.
Respondido : 09/12/2015 7:56 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Octoprint?
Hi Diego
Yes, its rather good. I have 2 printers and 2 RasPi 2B running OctoPrint. No problems with full control and can view and control the printers wherever I am.
Peter
Respondido : 09/12/2015 8:01 pm
richard.l
(@richard-l)
Miembro Moderator
Re: Octoprint?
This will be my weekend project. Hopefully it goes smooth.
Respondido : 09/12/2015 9:35 pm
PJR
 PJR
(@pjr)
Re: Octoprint?
Hi Richard
It really should take only an hour to set up, maximum 2 hours. If you have any queries, post them here.
Will you be connecting a webcam? What make/model? Wired or WiFi network? At least 8GB micro SD card?
Peter
Respondido : 10/12/2015 12:01 am
richard.l
(@richard-l)
Miembro Moderator
Re: Octoprint?
Webcam will be the Pi camera with a longer cable. Network will be wired since I will be powering the Pi from the Rambo. As for the SD Card, I'm not sure if I will go 8 or 16 GB. 8 should be plenty but I'm not sure if I can find an 8GB card here in town.
Respondido : 10/12/2015 4:38 am
PJR
 PJR
(@pjr)
Re: Octoprint?
Richard
When you start taking timelapse of long prints, you will need a bigger SD card. The images are stored individually in a temp folder and then rendered at the end. 16GB will be good.
OctoPi/Print should work without any config changes.
Peter
Respondido : 10/12/2015 10:05 am
richard.l
(@richard-l)
Miembro Moderator
Re: Octoprint?
Hmmm, hadn't thought about the need of the timelapse files. Maybe 32GB?
I will have to do some small configuring on the network settings as I prefer to use static IP addresses.
Respondido : 10/12/2015 4:20 pm
PJR
 PJR
(@pjr)
Re: Octoprint?
Hi Richard
I would say that timelapse is more of a "want" than a "need". I did it a few times, then got tired of it...
I think you can set up the NIC config on the Windows PC before moving the card across.
When I went to buy the SD card, 16GB was the best value-for-money, so I went with that.
Peter
Respondido : 10/12/2015 5:47 pm
