Linear Advance - Slic3r PE
Starlynk
(@starlynk)
Ok, I was reading the newlsetter and it said that the settings are already in Slic3r PE for the Linear Advance. I checked the gcode section of my filaments and cannot find any changes/additions.
Can we get a better guide for setting up Linear Advance through editing gcode?
Marlin site has good information about Linear Advance, but I don't want to screw something up if the new version of Slic3r PE already has changes made to it.
Respondido : 24/11/2017 2:52 am
maxx78
(@maxx78)
Re: Linear Advance - Slic3r PE
Do you have Slic3er PE 1.37.2 ?
look under Filament Settings-> Custom G-code
Respondido : 24/11/2017 10:46 am
Starlynk
(@starlynk)
Yup, I have the most recent version. I am guessing that since I do not use any of the default filaments, that may be the reason.
I did uncheck suppress default and even the default doesn't have any linear advance gcode.
Respondido : 24/11/2017 9:14 pm
in my PC, the single filament Slic3r, has linear advance settings in the filament Gcode section, but the MMU section does not have linear advance settings
as I currently only have an MMU printer in service, this is not very helpful.
Respondido : 24/11/2017 11:44 pm
Starlynk
(@starlynk)
Is there supposed to be a new text field for the M900 K setting? If so, that isn't showing in mine.
Respondido : 25/11/2017 2:09 am
Starlynk
(@starlynk)
Ok, found out what happened. Since I update via the github releases, I did not get all the default filaments you would get from a fresh install.
I uninstalled, downloaded the windows installer build and voila... the M900 K## is there in each filament. However I do not use those filaments, so all they are to me is a reference point for now before I remove them all.
So for anyone else looking for the M900 K code, it won't be in there unless you install from the windows installer file.
On a side note though, since M900 K code is going to be a constant in the 3D printing world (at least for a while), I would prefer to see a dropdown or textbox directly for it in Slic3r with use information. Then when you export the gcode, it automatically gets placed in the file as start code.
Respondido : 25/11/2017 5:41 am
richard.l
(@richard-l)
Miembro Moderator
Been out for a week and just catching up so this may be answered in another post somewhere that I haven't gotten to.
The M900 settings for the MMU are set in the printer G-code and not the filament G-code. In mine it shows M900 K200 as the last line.
Respondido : 01/12/2017 4:06 pm
Thanks. Nothing like standardisation. 🙂
Respondido : 01/12/2017 6:23 pm
