[Résolu] How to decrease overall print speed?
Kevlar
(@kevlar)
I am using Prusaslicer 2.1.0. Included is a simple model, but on 100% speed, it fails all the time. However, when I manually adjust the speed after it starts printing to around 50%, it prints great. I want to be able to set the print speed to whatever I want in the slicer so I don't have to Tune the print after it starts printing. Can someone tell me how, please?
Thank you.
Attachment removed
Best Answer by bobstro:
Posted by: @maincityimp
Thank you, Bobstro. So changing the, max volumetric speed, to something like 40 would prevent each print speed feature to not go over 40mm/s? I believe I tried this already but the percentage on the printer's display stayed at 100%. Is that what should happen, the speed on the display still shows 100% ?
Sort of. The MVS setting is measured in cubic mm/s (mm^3/s). The Prusa default is 15mm^3/s, so set it to something like 7mm^3/s. It won't change the speed displayed on the front panel. That corresponds to the M220 command and is what changes when you spin the front knob mid-print. If you want to see the changes, slice your part and spend some time in preview mode selecting the Speed view option.
Publié : 13/11/2019 1:27 am
RE: How to decrease overall print speed?
You can change speeds under Print Settings->Speed for individual features. A simpler approach is to reduce the Maximum volumetric speed on the same tab. This will allow printing at up to the speeds specified but apply a throttle when necessary to avoid exceeding the maximum rate the hotend is capable of processing.
Alternately, you could insert an M220 Sxx command into the startup gcode to set a reduced percentage.
Publié : 13/11/2019 2:01 am
2 personnes ont aimé
Kevlar
(@kevlar)
Publié : 13/11/2019 2:15 am
Publié : 13/11/2019 2:33 am
1 personnes ont aimé
Kevlar
(@kevlar)
Awesome! Thank you.
Publié : 13/11/2019 3:00 am
