ColorPrint insert filament loop?
blerghcity
(@blerghcity)
Hi all,
I tried my first ColorPrint today, a simple Game of Thrones coaster with a black coaster base and a red Targaryen logo on top. I used ColorPrint to insert a color change break at the appropriate height. The black base printed great but I faced 2 problems when it was time to change filaments:
  • The first filament didn't eject completely and I couldn't pull it out with any of the three options given during the switch procedure. Thus I had to hit 'Yes' as if the filament was changed, then immediately pause the print, then manually switch the filaments and continue. Has anyone else had a problem like this?
  • The bigger problem was even after this happened, right after the extruder seemed to be done with a section and hop to the next part, it would loop back to the insert filament, even though it already happened. It would never stop doing this, so I had to stop the print, and I ended up with just a black coaster.
  • I'm pretty new so I'm not sure what I did wrong. I think it may have something to do with 'Z hop' but I'm not sure what that even means yet, I'm just guessing. Also, I used the ColorPrint app included in the latest mac driver release, not the online version. Should I try the online version instead?
    Postato : 24/07/2017 5:28 am
    PJR
     PJR
    (@pjr)
    Antient Member Moderator
    Re: ColorPrint insert filament loop?
    You cannot use the colour print app if you have sliced with Z-Lift.
    You have to slice without Z Lift or you can slice with Z Lift and then insert the M600 code manually.
    Peter
    Postato : 24/07/2017 9:39 am
    AJS
     AJS
    (@ajs)
    As Peter said, the Lift causes Color Print to think it is going through that Z value multiple times. If you are using Slic3r, you must use the ColorPrint type of the printer, not the with Z-Lift. That will fix the repeated filament swaps.
    As far as the filament not unloading, that it typically a sign that your tensions screws are a bit too tight. They should be at about 14mm from the body with no filament in the extruder.
    Postato : 28/07/2017 3:25 pm
    tom.b6
    (@tom-b6)
    The Color Print site now has the following statement
    "Coloprint now works correctly even if your print settings contain hop or z­lif, you don’t to disable it anymore!".
    Sounds like they fixed it. It seems to work OK for me without disabling anything.
    Postato : 29/07/2017 2:57 pm
