Changed 1st layer fan settings or bug?
VTDuc
(@vtduc)
This has got me stumped for a few days now, even after reading through the G-code: Since I updated to the most recent version of the Prusa Slic3r software (Mac), when I print with PLA the print fan is ALWAYS ON when printing the first layer. That is not the case for models I sliced with previous versions of the software. Is Fan On the new default setting for the 1st layer even when “Disable fan for first 1 layers” is checked? I am a pretty confused at this point...
Thanks
Respondido : 20/07/2017 2:27 am
AJS
 AJS
(@ajs)
Re: Changed 1st layer fan settings or bug?
The fan for the heat break must always be on >50C, so I presume you mean the filament cooling fan (the one in front?).
I have not played with these settings in the new Slic3r, but you should have complete control over that fan.
Respondido : 20/07/2017 4:24 am
VTDuc
(@vtduc)
Yes, it's the blower fan mounted to the front of the extruder assembly. For PLA it should be off on the first layer but is not anymore. I will reslice some of my older projects to see what happens. Maybe comparing G-codes for the before and after upgrade files will help.
Respondido : 20/07/2017 7:19 pm
GunnerP
(@gunnerp)
I have the same issue with the newest version of Prusa Slic3r (Mac). Just today I sliced two models to print in PETG with an older version that has the layer fan disabled for the first 3 layers. After that I downloaded the newest version of Prusa Slic3r and sliced the same model with the same PETG settings with the layer fan disabled for the first 3 layers. When I went to print the new gcode file the fan wasn't disabled for the first 3 layers, it turned on immediately when the print started.
Probably just have to use the older version until the newest one gets fixed, I assume its probably just a bug.
Respondido : 21/07/2017 1:54 am
JuanCholo
(@juancholo)
oh is this 1.36.0? i just changed from 1.35.5.16
there was a bug noted for the first layers and the fan ignoring the disable command
"Fixed a regression after Slic3r 1.35.5.16, where the fan was started from the first layer,
not respecting the "Disable fan for the first n layers" value #418."
“One does not simply use a picture as signature on Prusa forums”
Respondido : 21/07/2017 4:48 am
VTDuc
(@vtduc)
I am using slicer version 1.35.5.21. I will install 1.36.0 to see if that fixes the problem.
Thanks for the pointer!
Respondido : 24/07/2017 11:26 pm
