Z calibration or extruder problem?
william.s7
(@william-s7)
I have been struggling all week trying to get the live adjust Z calibration correct using the V2Calibration.gcode. I watched every video and read every post I can find to be sure the probe high set correctly. Done the paper (.12mm) test under nozzle in middle of bed, used CC (.74mm) to set probe height, etc.
When I run the V2Calibration.gcode, the intro extrusion does not look correct and no matter where I set the live adjust Z setting, the filament will not stick to the bed.
I am wondering if I have some type of problem with extrusion? I have access to another Prusa i3 mk2s (Assembled by Prusa) and the attached picture shows the difference in the two printers. The black is from a working printer, the silver is from the non-working printer.
I have run out of ideas.
Any help appreciated.
Bill
Also any help posting jpegs too. I try attachments but they do not show up on post.
Respondido : 08/09/2017 2:28 am
AJS
 AJS
(@ajs)
Re: Z calibration or extruder problem?
Image did not post (?)
Respondido : 08/09/2017 2:44 am
william.s7
(@william-s7)
I can't get jpeg to attach. Tried different sizes without success.
https://plus.google.com/photos/photo/117801937707349217564/6463207504425851346?icm=false&iso=true&authkey=CILIru7kobus_wE
Respondido : 08/09/2017 2:51 am
AJS
 AJS
(@ajs)
Extruder problem. For sure.
Check here for common issues. Check those, and get back to us.
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Respondido : 08/09/2017 3:11 am
Vertigo
(@vertigo)
Im gonna disagree this is an extruder problem. Looks like plenty of filament is being extruded, just WAY too high.
Respondido : 15/09/2017 1:36 pm
william.s7
(@william-s7)
Re: Z calibration or extruder problem? Resolved
Factory reset, re-upload v3.0.12, factory reset. Recalibrated probe using metric set of feeler gauges and reran the steps from "Before you ask..." page, for the 20th time. Worked.
I think my problem on this was not doing the factory reset the first time I updated the firmware from v3.0.10.
Thanks for all the help.
Bill
Respondido : 17/09/2017 1:09 am
