Z axis alignment won't happen
Dežo
(@dezo-2)
During XYZ calibration, in the moment when Z axis should be aligned, movement upward stops after 4-5cm. This leads to incorrect calibration and failure during next step.
What could be the cause?
Thank you.
Posted : 12/01/2018 12:20 am
Martin Stoufer
(@martin-stoufer)
Re: Z axis alignment won't happen
Dezo, can you rotate the threaded rods by hand and move the gantry up past this point? Or does it abruptly stop on the way up?
I can't think of anything else aside from the vertical rods being skewed so much, it binds when being raised.
Posted : 12/01/2018 6:30 am
