XYZ calibrate FAIL (newbie)
NormalPrint
(@normalprint)
Hi
Just finished building i3 mk3 , self test runs fine, then goes to calibrate xyz and fails when printhead drops to the bed (Calibration failed! Check the axes and run again ) , was working before i updated to latest firmware FIRMWARE 3.1.1 RC4 B143 (DECEMBER 30, 2017)
thanks in advance
Publié : 05/01/2018 2:39 am
AJS
 AJS
(@ajs)
Re: XYZ calibrate FAIL (newbie)
Please try these steps and tell us what happens. We need more info to go on.
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Publié : 05/01/2018 3:45 am
NormalPrint
(@normalprint)
Yep checked all these things, same problem, doesn't seem to make a difference where pinda sensor is. Still fails..... 😥
Publié : 05/01/2018 9:51 am
NormalPrint
(@normalprint)
All sorted Thanks..... build mistake.... my bad 😈
Publié : 06/01/2018 7:48 am
Mkwiatkowski
(@mkwiatkowski)
I'm having a similar issue. Can you post what you did to fix your problem?
Publié : 10/01/2018 3:01 pm
Nimon Omaha
(@nimon-omaha)
Brennen, Im have this issue two. Can you please list out what build mistake you made? I may have made the same error.
thanks,
Publié : 03/02/2018 3:12 am
