X-axis Layer Shift in all prints
Brainafic
(@brainafic)
Hey!
I have been having this consistent problem on all my prints in the Mk2 that I built from the kit.
The printer seems to shift a bit on the x axis, you can see it in the attatched pictures.
I can't find what the problem is, however I have noticed the x-axis belt "twisting" when the x direction changes, I tried reassembling the x-axis, but nothing changed.
Do you guys have any suggedtion to get rid of the shifting?
The print in the attatched pictures was printed with PLA, and the following settings:
-Silent mode
-0.15mm layer height
-205C° extruder
-70C° bed
-wall speed: 60mm/s
-1.6mm walls
-0.8mm bottom/top
Thanks,
Franc
Postato : 17/02/2018 1:20 pm
Peter L
(@peter-l)
Re: X-axis Layer Shift in all prints
Check to make sure the screws holding the gear to the X axis stepper motor are tight and there's zero wiggle. I think the twisting of the belt (caused because the belt rubs against the idler) is a red herring. My printer does the same and I don't have the shifts you have.
Postato : 18/02/2018 3:00 am
AJS
 AJS
(@ajs)
I would try turning off silent mode.
And 60m/s is fast unless you are using Linear Advance. Are you using Linear Advance? (Which version of Firmware and is there a M900 K## in your gcode?)
And, as peter.I22 said, make sure the motor and tension on belt are tight.
Postato : 20/02/2018 5:59 am
Brainafic
(@brainafic)
Thanks for your answers!
I have been doing some tests, I think the broblem is not in the X-axis, or at least not only in the X-axis, because taking a closer look at my prints, the problem is also in y axis.
I think the right term for my problem is "Banding" (sorry, but english is not my mother tongue haha)
Peter.l22:
I checked all the screws and took a look at the whole printer, I noticed that the metal frame was too low, so much that it was toching the desk where I have the printer and it was causing a lot of vibration, I solved that, and there is a lot less vibration, and the banding got better, but it is still not good.
Belts and screws are tight, but the bed seems to wiggle just a little bit, but I would say it is normal to have a bit of tolerance?
aaron.s5:
I tried high power mode, but the problem persists.
As for the Linear advance, I had no idea this existed until now, I have FW 3.1.0 so I whould be able to make use of this. I use Cura for slicing, I checked the gcode and there isn't M900 K##, apparently, in Cura it has to be done manually, I will try and let you guys know how it goes.
I add some more pictures in case they are useful.
Thanks a lot for your help!!
Postato : 20/02/2018 10:22 am
Peter L
(@peter-l)
It is actually normal to see some slight differences in the outer wall depending on whether you've got infill, a thick wall, or a thin wall on the other side. That's because the toolpath will be slightly different.
I'd suggest setting the slicer to print perimeters first. That should minimize the effect.
Postato : 20/02/2018 4:57 pm
AJS
 AJS
(@ajs)
Agree. Perimeters first, and slow perimeters down to 40m/s.
Postato : 21/02/2018 3:22 am
