Working printer does not start cleaning nozzle now
francesco.m2
(@francesco-m2)
Hey,
I have an MK2 kit and a couple of months back it was working fine. I have been away for 3.5 months and when I start it now it first said "Printbed mintemp" or something. It has been in my garage where its been 8-10 degrees Celsius. I did an Self test and it went out fine. I also pumped up the temperature to 20 degrees.
When I try now it starts with the calibration but when it should start to clean the noozle it never starts. Just stops an sits there and the percentage goes fast.
Someone else had the issues and it was due to a faulty SD card, so I changed it to one that worked before. = Same issue
I tried some native printmodels that came with the printer = Same issue
Any more ideas? The printer hasn´t been moved so it should be any issues there.
Opublikowany : 04/03/2018 7:20 pm
francesco.m2
(@francesco-m2)
Re: Working printer does not start cleaning nozzle now
I solved it my self.
After a restart and I removed the tape I used for adhesion and it worked after that.
Opublikowany : 04/03/2018 7:57 pm
