Calibration half way up the Z Axis.
Hi everyone!
Been loving my mk2 for over a year now, until the point where I was cleaning out the nozzle, overtightened the heatbreak and snapped it.
I bought some replacement parts and have fitted them. All is ok hardware wise.
Since then I have had trouble doing xyz calibration. Point 2 of 4 would be oddly high off the bed, and after 3 iterations I got the generic error meaning the points were found way off.
So I did a factory reset. Now when I run the xyz calibration it only travels about half way down the z axis before checking for the first point.
Any ideas?
Re: Calibration half way up the Z Axis.
Maybe an update to the latest firmware and then redo calibration beginning with the selftest.
Bill
Tagaytay City, Philippines
Yeh I have done this.
by grivvr » 08 Mar 2018 21:13
Please check which hex file you downloaded - it is just possible you accidentally clicked the wrong download link.
Bill
Also try a factory reset -> Delete all data.
Sometimes data gets corrupted and creates strange artifacts.
