        what should the frame bottom clearance from the table be?
HI, i'm building my mk2s kit and have reached step1 in preflight check (9.1). Turns out my bed isn't level at all, so i take a look and the frame ends are at different heights from the desk. What should be the clearance? I get psu end @2.9mm and rambo end @2.3. I've untightened the m10 nuts just to make sure the whole Y assembly is sitting as low as possible in the frame. Is there a case for me to lower the frame in the higher side to try to get level? Or would that compound problems later on?
cheers.
                            Posted : 11/12/2017 1:14 pm
