what should the frame bottom clearance from the table be?
chris.b35
(@chris-b35)
HI, i'm building my mk2s kit and have reached step1 in preflight check (9.1). Turns out my bed isn't level at all, so i take a look and the frame ends are at different heights from the desk. What should be the clearance? I get psu end @2.9mm and rambo end @2.3. I've untightened the m10 nuts just to make sure the whole Y assembly is sitting as low as possible in the frame. Is there a case for me to lower the frame in the higher side to try to get level? Or would that compound problems later on?
cheers.
Veröffentlicht : 11/12/2017 1:14 pm
