V2 Calibration for .25 nozzle
Michael Roth
(@michael-roth)
Is there a V2 Calibration gcode for for the different nozzle sizes? I'm looking for one for a .25 nozzle.
Thanks!
Napsal : 20/03/2017 2:08 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: V2 Calibration for .25 nozzle
➡ have a look at my "life adjust z - my way" thread here.
🙄 i just added a version for 0.25mm nozzles. but it's untested (got only 0.40mm nozzles).
so it would be nice if you'll leave a comment after testing the calibration gcode.
behaviour should be the same as for the previous (0.40mm) versions: lower the z-live value (make it more negative) until the filament sticks properly to the printbed and the result is a unique sheet / film (no separte strains). then take out your digital calliper and optimize the adjustment until you've found the minimum.
:mrgreen: and yes: in the middle of the print there is a short acoustic signal, that reminds you to change the adjustment value (i recommend to read the whole thread mentioned) and the "magic" g-commands, that tell the printer that he should remember the z-adjustment value and shouldn't complain anymore, are also included.
Napsal : 20/03/2017 9:11 pm
Michael Roth
(@michael-roth)
Thanks! I'll give it a try soon & let you know.
Mike
Napsal : 21/03/2017 12:54 pm
