USB Cura print will not trigger auto-calibrate?
WildBill
(@wildbill)
When I print the calibration print, and the Prusa logo from the SD card, the printer does the 9 point calibration, smears the test strip at the front left edge of the hot plate, then creates the border and finally prints.
When I print from Cura via USB, the printer appears to do nothing but find the home button and then begins the print.
What am I doing wrong?
Postato : 07/10/2016 6:07 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: USB Cura print will not trigger auto-calibrate?
Bill
Start GCode - Include G80 following the G28 (Home)
Peter
Postato : 07/10/2016 6:31 pm
WildBill
(@wildbill)
Is there no way to get Cura to add that automatically as a default option? Or do I need to do it with a text editor with every file I make?
Postato : 07/10/2016 6:52 pm
PJR
 PJR
(@pjr)
Bill
Not using Cura at the moment, so I can't really assist any further. WHich Cura version are you running?
Peter
Postato : 07/10/2016 7:16 pm
WildBill
(@wildbill)
Peter;
Thanks for the G80. At least that's somewhat better.
Is there a code to make it do the pre-print smear at the front left edge of the bed?
Cura 2.1.3 Beta, linked from this site.
-Bill
Postato : 07/10/2016 7:34 pm
PJR
 PJR
(@pjr)
Bill
I only have Cura 15.04.6 - which works quite nicely.
Here's the start code to draw a line:
M83 ; Relative extruder
G1 Y-3.0 X50.0 F1000.0 ; go outside print area
G1 X100.0 E5 F1000.0 ; intro line
G1 E-0.5 Z2 F1000 ; Retract a bit and lift nozzle
G92 E0.0 ; Zero extruder
The codes are reasonably well documented.
Peter
Postato : 07/10/2016 7:47 pm
