uneven z lines
alex.a5
(@alex-a5)
uneven z lines
Built my MK2s printer last week and has mostly been a smooth ride. Had a few issues, which I found solutions for on this forum!!
Very helpful.
Haven't seen a solution to this one thought.
Have I gotten a X&Y perpendicular message in the calibrations, doubled checked my axis and tightened all bolts.
No noticeable wobble when it's moving.
I get these anomalies on all my prints, sometimes worse.... (i sanded them down.. forgot to take a screenshot)
So i printed this little octogon to show the lines. Any ideas what i can do?
This is Prusa white PLA.
have adjusted the flow... no luck.
printed @ 2.0mm using Prusa Control.
Thanks for your help!
Napsal : 14/08/2017 2:56 pm
AJS
 AJS
(@ajs)
Re: uneven z lines
There are a number of possible causes for this.
Some are within the slicer, some are mechanical.
Do you get these on pre-sliced model or only ones you sliced?
Check here for some common causes:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Let us know if not these and we can check more.
Napsal : 14/08/2017 9:29 pm
alex.a5
(@alex-a5)
Re: uneven z lines
So,
I've gone through the link.
I've done the 2 temperature calibrations.
I adjusted the y and x belts, made sure the idlers were aligned better.
This is another model i sliced with prusa control, same as the picture before.
I've done full z calibration, printing the squares and aligning them.
My belts arn't loose,
I adjusted the y belt position by a mm front and back, (i was off from the build instructions)
please advice
thanks for your help!
Napsal : 15/08/2017 2:24 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: uneven z lines
As Aaron has suggested, print one of the pre-sliced models from the SD card (Adalinda or the Castle).
Peter
Napsal : 15/08/2017 2:36 pm
alex.a5
(@alex-a5)
Re: uneven z lines
hmmm okay... i'll print Adalinda tonight... (it's 11pm atm),
don't want to print the castle if i don't have to... thats 23hrs~
if i have time in the morning i'll upload a pic
thanks
Napsal : 15/08/2017 2:53 pm
Hackinistrator
(@hackinistrator)
Re: uneven z lines
you need to print something with flat vertical surface .printing adalinda wont help much , just a waste of filament .
if its repeating pattern that changes depending on your part size , then it could be uneven filament diameter .
try printing same part at different locations on the bed
Napsal : 15/08/2017 8:18 pm
alex.a5
(@alex-a5)
Re: uneven z lines
For the most part the adalinda dragon came out good!. Some of the lines are still present.
So the image i posted above. I printed two of them... and the pattern seams to be identical. Havent tried a different part of the bed yet.
Napsal : 16/08/2017 12:53 am
alex.a5
(@alex-a5)
Re: uneven z lines
Napsal : 16/08/2017 12:56 am
AJS
 AJS
(@ajs)
Re: uneven z lines
So, I think we need to focus on your slicer settings.
Please post your settings for the prints with stripes.
Napsal : 16/08/2017 6:24 am
alex.a5
(@alex-a5)
Re: uneven z lines
As i said earlier, was using prusa control... so the settings are limited.
I can switch to the Prusa Slic3r edition and print slice with that.
On the prusa control, i'm just adding Brim and settings it to 0.2mm with a 20% fill
Napsal : 16/08/2017 7:38 am
AJS
 AJS
(@ajs)
Re: uneven z lines
What temperature are you printing at?
How does that compare to the temp of the pre-sliced file that printed well?
My suggestion is to check temperature and speeds. I don't use Prusa Control so I can't help specifically.
Try one of your models but slow the print down to 80% from the front panel and see if that helps.
Napsal : 16/08/2017 4:59 pm
boofingAcid
(@boofingacid)
Re: uneven z lines
Out of curiosity as I've had similar problems, are there any specific settings you look for when there are shifted Z layers?
Jordan
Napsal : 16/08/2017 7:15 pm
alex.a5
(@alex-a5)
Re: uneven z lines
Been printing at the default 210 deg.
Ok. So i sliced the model in slic3r prusa edition and the results are much better !
Still displays some lines but its much butter.
The picture attached left is prusa control. settings 0.2mm 20% infill 210 deg.
Slicer i tried to set the same. Using the latest preset from github.
Napsal : 17/08/2017 1:13 am
alex.a5
(@alex-a5)
Re: uneven z lines
Sending from my phone. Couldnt attach txt file.
; generated by Slic3r 1.36.2-prusa3d-stable-win64 on 2017-08-16 at 23:15:08
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.42mm
avoid_crossing_perimeters = 0
; bed_shape = 0x0,250x0,250x210,0x210
; bed_temperature = 55
; before_layer_gcode =
; bridge_acceleration = 1000
; bridge_fan_speed = 100
; brim_width = 4
; complete_objects = 0
; cooling = 1
; default_acceleration = 1000
; deretract_speed = 0
; disable_fan_first_layers = 1
; duplicate_distance = 6
; end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n"
; end_gcode = G4 ; wait\nM104 S0 ; turn off temperature\nM140 S0 ; turn off heatbed\nM107 ; turn off fan\nG1 X0 Y200; home X axis\nM84 ; disable motors
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_colour = #FFFF00
; extruder_offset = 0x0
; extrusion_axis = E
; extrusion_multiplier = 1
; fan_always_on = 1
; fan_below_layer_time = 100
; filament_colour = #FF14E2
; filament_cost = 0
; filament_density = 0
; filament_diameter = 1.75
; filament_max_volumetric_speed = 0
; filament_notes = "List of materials tested with standart PLA print settings for MK2:\n\nDas Filament\nEsun PLA\nEUMAKERS PLA\nFiberlogy HD-PLA\nFillamentum PLA\nFloreon3D\nHatchbox PLA\nPlasty Mladeč PLA\nPrimavalue PLA\nProto pasta Matte Fiber\nVerbatim PLA\nVerbatim BVOH"
; filament_soluble = 0
; filament_type = PLA
; first_layer_acceleration = 1000
; first_layer_bed_temperature = 55
; first_layer_extrusion_width = 0.42
; first_layer_speed = 70%
; first_layer_temperature = 215
; gcode_comments = 0
; gcode_flavor = reprap
; infill_acceleration = 2000
; infill_first = 0
; layer_gcode =
; max_fan_speed = 100
; max_layer_height = 0.25
; max_print_speed = 100
; max_volumetric_extrusion_rate_slope_negative = 0
; max_volumetric_extrusion_rate_slope_positive = 0
; max_volumetric_speed = 0
; min_fan_speed = 85
; min_layer_height = 0.07
; min_print_speed = 15
; min_skirt_length = 4
; notes =
; nozzle_diameter = 0.4
; only_retract_when_crossing_perimeters = 0
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; perimeter_acceleration = 800
; post_process =
; printer_notes =
; resolution = 0
; retract_before_travel = 1
; retract_before_wipe = 0%
; retract_layer_change = 1
; retract_length = 0.8
; retract_length_toolchange = 3
; retract_lift = 0.5
; retract_lift_above = 1
; retract_lift_below = 199
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 0
; retract_speed = 35
; single_extruder_multi_material = 0
; skirt_distance = 2
; skirt_height = 3
; skirts = 1
; slowdown_below_layer_time = 25
; spiral_vase = 0
; standby_temperature_delta = -5
; start_filament_gcode = "; Filament gcode\n"
; start_gcode = M115 U3.0.12 ; tell printer latest fw version\nM83 ; extruder relative mode\nM104 S[first_layer_temperature] ; set extruder temp\nM140 S[first_layer_bed_temperature] ; set bed temp\nM190 S[first_layer_bed_temperature] ; wait for bed temp\nM109 S[first_layer_temperature] ; wait for extruder temp\nG28 W ; home all without mesh bed level\nG80 ; mesh bed leveling\nG1 Y-3.0 F1000.0 ; go outside pritn area\nG1 X60.0 E9.0 F1000.0 ; intro line\nG1 X100.0 E12.5 F1000.0 ; intro line
; temperature = 210
; threads = 4
; toolchange_gcode =
; travel_speed = 120
; use_firmware_retraction = 0
; use_relative_e_distances = 1
; use_volumetric_e = 0
; variable_layer_height = 1
; wipe = 1
; wipe_tower = 1
; wipe_tower_per_color_wipe = 15
; wipe_tower_width = 60
; wipe_tower_x = 180
; wipe_tower_y = 140
; z_offset = 0
; clip_multipart_objects = 1
; dont_support_bridges = 1
; elefant_foot_compensation = 0
; extrusion_width = 0.45
; first_layer_height = 0.2
; infill_only_where_needed = 0
; interface_shells = 0
; layer_height = 0.2
; raft_layers = 0
; seam_position = nearest
; support_material = 0
; support_material_angle = 0
; support_material_buildplate_only = 0
; support_material_contact_distance = 0.15
; support_material_enforce_layers = 0
; support_material_extruder = 0
; support_material_extrusion_width = 0.35
; support_material_interface_contact_loops = 0
; support_material_interface_extruder = 0
; support_material_interface_layers = 2
; support_material_interface_spacing = 0.2
; support_material_interface_speed = 100%
; support_material_pattern = rectilinear
; support_material_spacing = 2
; support_material_speed = 50
; support_material_synchronize_layers = 0
; support_material_threshold = 35
; support_material_with_sheath = 0
; support_material_xy_spacing = 60%
; xy_size_compensation = 0
; bottom_solid_layers = 5
; bridge_flow_ratio = 0.95
; bridge_speed = 20
; ensure_vertical_shell_thickness = 1
; external_fill_pattern = rectilinear
; external_perimeter_extrusion_width = 0.45
; external_perimeter_speed = 30
; external_perimeters_first = 0
; extra_perimeters = 0
; fill_angle = 45
; fill_density = 20%
; fill_pattern = cubic
; gap_fill_speed = 40
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0.45
; infill_overlap = 25%
; infill_speed = 60
; overhangs = 0
; perimeter_extruder = 1
; perimeter_extrusion_width = 0.45
; perimeter_speed = 40
; perimeters = 2
; small_perimeter_speed = 20
; solid_infill_below_area = 0
; solid_infill_every_layers = 0
; solid_infill_extruder = 1
; solid_infill_extrusion_width = 0.45
; solid_infill_speed = 40
; thin_walls = 0
; top_infill_extrusion_width = 0.4
; top_solid_infill_speed = 30
; top_solid_layers = 6
Napsal : 17/08/2017 1:14 am
alex.a5
(@alex-a5)
Re: uneven z lines
reading online,
i should try a temperature tower, and find the best temp to print this filament at. I read that white pla can string easily?
so many a lower temp might solve the remainder of my issues.
Any thoughts?
Napsal : 17/08/2017 6:07 am
AJS
 AJS
(@ajs)
Re: uneven z lines
Temperature is a variable that you should look into, for your filament.
Most PLA's are quite forgiving, but I have had some minor sensitivities with both a white and a red.
Napsal : 17/08/2017 4:15 pm
