Top X carriage rod getting stuck from time to time, weird pattern
murloc992
(@murloc992)
Hello,
I have noticed that no matter how I lubricate the printer now, X carriage top smooth rod is getting stuck..
Also there's this pattern I didn't see before:
What is this? The whole rod looks like candy cane.
Maybe my top rod is bent?
Opublikowany : 21/05/2017 9:09 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Top X carriage rod getting stuck from time to time, weird pattern
do you use drylin bearings (which normally shouldn't be lubricated) ?
seems like binding due to a slight misalignment between the two upper bearings at the x-axis carriage.
Opublikowany : 21/05/2017 9:14 pm
murloc992
(@murloc992)
Yes I use dryLin, and use the dry teflon spray.
Can it also have something to do with the tensioners on the PSU side of X carriage?
I will try to reseat the bearings again..
Opublikowany : 21/05/2017 9:26 pm
JeffJordan
(@jeffjordan)
Member Moderator
Can it also have something to do with the tensioners on the PSU side of X carriage?...
❓ do you mean the two m3 screws at the right side of the x-end idler part (with their square nuts assembled inside the notches of the x-end idler part) ?
➡ they are not ment to tension the x-belt ! they are simply to adjust the overall length of the x-carriage, including the rods, to a length that fits the distance between the two z-axis rods and the z-axis spindles.
if the length is properly adjusted, you shouldn't notice any out- or inwards force provided by the x-carriage at the z-rods. neither in bottom nor in top position ❗
Opublikowany : 21/05/2017 11:06 pm
murloc992
(@murloc992)
Apparently I might have had my zip ties on the bearings tightened too much. Replacing the zip ties with less pressure fixed the issue. Yay. 🙂
Opublikowany : 22/05/2017 1:09 pm
Knickohr
(@knickohr)
Member Moderator
Hot news from igus :
My new SWM-08 rods get some surface rust.
Drylin and lubricating
Symptom:
The linear bearing system ran smoothly for a number of cycles, but after a number of cycles, friction forces increased or binding occurred.
Solution:
Plastic bushings are a great alternative to metal ball bearings since they are dry-running and do not require external lubrication. igus®’ line of plastic bushings, for example, use dry lubricants such as PTFE and silicone.
Thomas
Opublikowany : 10/07/2017 1:26 pm
