Top Layer Problem
kashyap.s
(@kashyap-s)
Top Layer Problem
Hello
I have recently noticed that when I am printing the top layers do not go all the way to the edge, Please see the photo to see what I am talking about. I have tried to increases the top infill layer setting in Slic3r with not benefit.
https://www.dropbox.com/sh/mpqq4rijm1pnjy9/AAAnx6ao9CQtgZNZpqBXtLrga?dl=0
Thanks
Postato : 25/12/2015 10:35 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Top Layer Problem
Hi
You need to increase the loop/solid infill overlap. This is the setting in KISSlicer; I don't use Slic3r, so I can't tell you the setting name for that slicer, sorry.
Peter
Postato : 26/12/2015 12:06 am
kashyap.s
(@kashyap-s)
Hello
At what value do you have your infill overlap?
Thanks
Postato : 26/12/2015 12:10 am
PJR
 PJR
(@pjr)
In KISSlicer, I have it set at 0.5.
There is a calibration for this. Please see the attached document.
Peter
Postato : 26/12/2015 12:27 am
