Thermal instabilities on heated bed
murloc992
(@murloc992)
Hello,
I wanted to ask what is going on with my heated bed. I have been seeing these dips at least once or twice per hour on long prints, but now it has gone quite insane.
Any ideas or solutions?
Respondido : 18/07/2017 2:10 pm
JeffJordan
(@jeffjordan)
Miembro Moderator
Re: Thermal instabilities on heated bed
the temperature of the heatbed couldn't change that fast and in this erratic way !
so you've (1) either got your thermistor loose (check if it's fixed secure with kapton tape underneath the heatbed), a defective thermistor wire (2) or a badly crimped connector plugged into the rambo board (3).
yes, ok, it's possible that the thermistor itself is refusing its job as well (4).
most likely will be #2.
Respondido : 18/07/2017 2:38 pm
murloc992
(@murloc992)
Yup.. it was a broken wire.. Apparently I have ziptied it too hard or something and it just broke off..
Is it possible to replace the cable itself? Say I cut whole cable leaving few cms to the socket and the thermistor? Does wire gauge matter?
Respondido : 18/07/2017 5:38 pm
JeffJordan
(@jeffjordan)
Miembro Moderator
...Is it possible to replace the cable itself? Say I cut whole cable leaving few cms to the socket and the thermistor? Does wire gauge matter?
yeah, no problem. wire gauge doesn't really matter for the thermistor.
Respondido : 18/07/2017 10:03 pm
