Sewing Machine Oil
kimmo.h
(@kimmo-h)
Sewing Machine Oil
Hi!
Would it be a good idea to lubricate the rods with a dropp of Sewing Machine Oil?
//Kimmo
Opublikowany : 14/11/2017 7:38 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Sewing Machine Oil
beside sticky hardoil nearly any oil will do the job.
furthermore it's recommended not to use oils with a high content of polyunsaturated fatty acid, because they might spoil your nose when they oxidise. 🙄
💡 personally I prefer a drop of simple SAE 5W30 motor oil, which lasts longer than very thin oil like valve oil (for trombones and trumpets).
anyhow: only a tiny drop is required.... and just for steel rods in combination with ordinary bearings. don't use oil if you've got drylin's.
Opublikowany : 14/11/2017 10:06 pm
kimmo.h
(@kimmo-h)
Hi Jeff!
Thx for your advice, i will look what i can find in my garage, remember that i bought some
motor oil for my lawnmower 🙂
Opublikowany : 15/11/2017 12:57 pm
