[Zamknięte] SD Card reader not working
Strona 5 / 5
christophe.p
(@christophe-p)
Member Moderator
Re: SD Card reader not working
I just tried it, and exFAT seems a no go, even with MBR partition table.
I'm like Jon Snow, I know nothing.
Opublikowany : 08/04/2017 5:48 pm
elena.s
(@elena-s)
Hi, my printer suddenly refused to read my 2 cards, that were working fine today, and I thought of cleaning them with contact cleaner (IPA based) so whaddya know, they work! Happily printing right now!
Opublikowany : 13/04/2017 6:34 pm
juanbenitezgarcia
(@juanbenitezgarcia)
I just received an MK3 and it does not read my SD card.
Invoice 182140325
Opublikowany : 26/08/2018 6:55 pm
Try pulling the card out < 1mm and see if it is recognized.
Opublikowany : 26/08/2018 7:36 pm
pierre.c2
(@pierre-c2)
That worked for us. Pull the card out about a milimeter and press the X. The card reader has been working for about a year before this.
Opublikowany : 28/09/2018 6:43 am
jasper.m
(@jasper-m)
Just finished building my I3. When I insert the SD card, the LCD says card inserted. However on the scroll menu it says no sd card and if I click this, there are no files shown despite the fact that there are several files on the card....advice?
I have the same problem.
Prusa sent out a different display, but the problem persists. 🙁
mobdro
Opublikowany : 19/12/2018 11:33 am
Mustrum Ridcully
(@mustrum-ridcully-2)
did you also change the display ribbon cable and check for bent pins in both where it plugs into the display and into the EINSY? also triple check it is plugged in properly not backwards on one end or offset by one pin.
Opublikowany : 20/12/2018 4:05 am
Joni the great
(@joni-the-great)
RE: SD Card reader not working
Same issues here. if i push an SD card in all it gives me is a folder icon even though there are files on the SD card. Cant really do anything with my printer because of this
Opublikowany : 03/07/2019 5:11 pm
Joni the great
(@joni-the-great)
Posted by: joan.t
Display shows card present
Shows card removed
Shows card re inserted...   Did this issue get resolved???
Opublikowany : 03/07/2019 5:13 pm
nadirchalin
(@nadirchalin)
I solved this problem by downloading this program and formatting my SD card from here!
https://www.sdcard.org/downloads/formatter/
I hope it will help you
Opublikowany : 24/04/2020 6:30 am
Leoyeung
(@leoyeung)
I am a Mac I brought the assembled version.
“When I insert the SD card, the LCD says card inserted. However on the scroll menu it says no sd card and if I click this, there are no files shown despite the fact that there are several files on the card....advice?”
I have the same problems.
how can I fix it ?
Opublikowany : 11/05/2020 6:47 pm
@leoyjobs
Format the SD card with "SD Card Formatter". You should also make sure that there are no special characters in the file name.
SD Card Formatter: https://www.sdcard.org/downloads/formatter/
Opublikowany : 11/05/2020 7:01 pm
DCBolt
(@dcbolt)
my MK3S / MMU2S also just stopped reading SD cards today. I've tried everything I can think of, factory resetting, firmware updating, firmware back-logging.. multiple SD cards, reformatting SD cards... same results.  I'm getting the "External SPI flash W25X20CL is not responding. Language switch unavailable" which to my understanding is a memory issue and shouldn't affect the ability to read SD cards. It detects when an SD card is inserted, loads to the root and shows as empty- if i go back into the menu it then says "No SD Card"....?  the drive on the screen says "F?"
Anyone have this same issue or can think of something I haven't tried yet???  Thank you!
Opublikowany : 03/06/2020 9:10 pm
@devin
Maybe your einsy or the card reader ( https://help.prusa3d.com/en/article/external-spi-flash-w25x20cl-not-responding-error_112019 ) is faulty. I would contact the Prusa chat.
Did you check all connections from einsy to the LCD display (ribbon cable)?
Opublikowany : 03/06/2020 9:56 pm
Sean Frantti
(@sean-frantti)
@devin
This same thing happened to me today after many months of successful use.... did you ever get a resolution?
Opublikowany : 03/08/2020 12:37 am
DCBolt
(@dcbolt)
@sean-frantti - Yes, Prusa ended up sending out a replacement board
Opublikowany : 04/08/2020 12:45 pm
Sean Frantti
(@sean-frantti)
@devin
  • Thanks for the response.  I emailed info@prusa a couple days ago with the issue but haven’t received any response , is there a better/recommended way to ask for help?
Opublikowany : 04/08/2020 2:35 pm
@sean-frantti
Login with your Prusa account; select eshop; after a few seconds the chatwindow will appear on the right bottom.
Opublikowany : 04/08/2020 2:49 pm
Strona 5 / 5
