SCAD files wrong dimensions
AnilM3
(@anilm3)
Hi Everyone,
I've been trying to print the parts for the printer directly from the scad files, generating an STL with OpenSCAD, but after the part was printed I noticed that the holes were smaller than they should have been. I've only printed the x-end-idler and the x-end-motor parts. I checked the source code and for some reason the bearing is set to a diameter of 14.5mm and the smooth rod to 7.8.
Is there a particular reason for this? Was this intentional?
Thanks!
Publié : 13/04/2016 11:14 pm
Stefan Krister
(@stefan-krister-2)
Re: SCAD files wrong dimensions
Hi Anil,
I think it's intentional. You have to be smaller to get a tight fit for the rods. The bearing part is sliced, so it can give enough room to the inserted bearings.
Regards
Stefan
OpenLab Augsburg e.V.
- Baeckergasse 32, 86150 AugsburgEvery Tuesday we meet to talk about 3D printing and share our experiences with our printing projects. We tinker, design, draw and print using the 3D printers available in…
Publié : 04/05/2016 3:28 pm
warandv
(@warandv)
could you please share the stl files repository link for the Prusa kit ?
Publié : 29/06/2016 8:43 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Depends what you are looking for but it's all in here : https://github.com/prusa3d
Ensure you select the correct branch.
Peter
Publié : 29/06/2016 9:14 pm
