Recommendation for replacement linear bearings
Wirlybird
(@wirlybird)
Hi all,
I know there are talks on this but wanted to revisit it a bit. What would be a recommended straight replacement for the original bearings on the MK2?
I don't have noise issues or anything else but just want to get some stocked up for future use. Always keep a good supply of spare parts for my printers!
I have a set of the Igus Drylin bearings I was going to use for the build but when I saw the slop in them I went with the original supplied bearings and they have been fine.
I am just looking for suggestions for a quality direct replacement.
Thanks for any info.
Opublikowany : 29/11/2016 2:32 pm
StephanK
(@stephank)
Re: Recommendation for replacement linear bearings
I guess Misumi LMU-8 would fit your needs.
Good quality, direct replacement, not too expensive...
Opublikowany : 29/11/2016 6:43 pm
Wirlybird
(@wirlybird)
Thanks for the suggestion. As i looked through older posts I did see this one come up. Looks to be cost effective.
Opublikowany : 29/11/2016 8:04 pm
