RAMPS 1.4 LCD to RAMBO mini
pottedmeat7
(@pottedmeat7)
I have this LCD Kit that works with RAMPS 1.4 and Mega 2560
https://www.sainsmart.com/sainsmart-smart-controller-ramps-1-4-lcd-12864-led-turn-on-control-for-3d-print.html
Will this LCD work with the RAMBO mini and the MK2 software?
If not where can I get the LCD for the MK2?
Publié : 11/03/2017 3:42 am
gabriele.s2
(@gabriele-s2)
Re: RAMPS 1.4 LCD to RAMBO mini
I don't think so, this one looks like the correct one but others should confirm: https://www.sainsmart.com/sainsmart-3d-printer-sanguinololu-reprap-lcd-2004-controller-adapter-sd-reader-1.html
- Gab
Publié : 11/03/2017 5:26 am
pottedmeat7
(@pottedmeat7)
any way to use the MK2 without the LCD?
Publié : 11/03/2017 5:33 am
gabriele.s2
(@gabriele-s2)
Not sure if it works when the LCD module is disconnected - but you can control the printer from a computer via a USB cable.
A lot of people use a Raspberry Pi with OctoPrint installed.
I think though that some functions such as self test and calibration are only available via the LCD screen.
- Gab
Publié : 11/03/2017 12:22 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
If you are able to amend and compile the firmware, you may be able to get that LCD/controller to work. There are various option in Configuration.h:
//LCD and SD support
#define ULTRA_LCD //general LCD support, also 16x2
//#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family)
#define SDSUPPORT // Enable SD Card Support in Hardware Console
//#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error)
#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication
#define ENCODER_PULSES_PER_STEP 2 // Increase if you have a high resolution encoder
#define ENCODER_STEPS_PER_MENU_ITEM 2 // Set according to ENCODER_PULSES_PER_STEP or your liking
//#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store.
//#define ULTIPANEL //the UltiPanel as on Thingiverse
//#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click
//#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click
// The MaKr3d Makr-Panel with graphic controller and SD support
// http://reprap.org/wiki/MaKr3d_MaKrPanel
//#define MAKRPANEL
// The RepRapDiscount Smart Controller (white PCB)
// http://reprap.org/wiki/RepRapDiscount_Smart_Controller
#define REPRAP_DISCOUNT_SMART_CONTROLLER
// The GADGETS3D G3D LCD/SD Controller (blue PCB)
// http://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel
//#define G3D_PANEL
// The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PCB)
// http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
// ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: http://code.google.com/p/u8glib/wiki/u8glib
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// The RepRapWorld REPRAPWORLD_KEYPAD v1.1
// http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click
// The Elefu RA Board Control Panel
// http://www.elefu.com/index.php?route=product/product&product_id=53
// REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARDUINO library folder: https://github.com/kiyoshigawa/LiquidCrystal_I2C
//#define RA_CONTROL_PANEL
Peter
Publié : 11/03/2017 10:19 pm
pottedmeat7
(@pottedmeat7)
I will try this. Although my printer is disassembled at the moment. Can I upload the firmware to the board and test the LCD over USB without a fully connected board?
Also manuals say that the LCD connectors have one/two stripes however both my connectors only have one. So not really sure where to connect these either...
Publié : 12/03/2017 11:24 pm
PJR
 PJR
(@pjr)
The stripes referred to are black marker pen at each end; not the red stripe along the length.
The red stripe should go to pin 10 at each end. Finding out which socket goes into which plug is trial and error; getting it wrong should not cause a problem.
The processor on the RAMBo can be powered via the USB cable so you can upload the firmware without other power, but the LCD may require power from the PSU.
Peter
Publié : 13/03/2017 1:54 pm
pottedmeat7
(@pottedmeat7)
I can hook up my PSU if necessary. But I'm a bit confused and don't wan't to blow up my RAMBO.
I have a PSU with two negative and two positive wires (exposed wires) but I don't have any type of Molex connector Like in the manual... http://manual.prusa3d.com/Guide/8.+Electronics+assembly/110#s1716
So i'm not too sure how to connect my PSU where do the negative's and positive's go?
I saw this
So two separate positive and negative sets from the PSU go into this connection (to provide motors and heatbed a separated power source) correct?
Also I could get an appropriate connector to clean up my wiring, what type is it to use?
Thanks!
Publié : 13/03/2017 6:55 pm
john.r6
(@john-r6)
Having tried this recently, there are problems in the firmware that may need fixing out before you can try it. As it stands, the firmware won't compile if you enable the fall graphic controller. The SD card driver gave issues I seem to remember for a start, but even with that disabled there were other issues. While the standard firmware compiled OK it's possible I didn't have the Arduino environment set up as was needed.
Might be worth seeing if you can get the firmware to compile first.
Publié : 13/03/2017 10:22 pm
PJR
 PJR
(@pjr)
I think this is the connector: http://shop.prusa3d.com/en/mk2-spare-parts/125-rambo-mini-heatbed-connector.html
You should have some from the original printer and/or RAMBo. PSU power needs to go to input B for processor.
Peter
Publié : 13/03/2017 11:09 pm
pottedmeat7
(@pottedmeat7)
Well actually I think it's sounding like it will be a hassle to try and use this LCD.
Will be much easier if I just buy the right one.
Is this
the right one?
Publié : 14/03/2017 12:41 am
PJR
 PJR
(@pjr)
Best thing is to contact support using live chat to see if they will sell you a replacement.
Peter
Publié : 14/03/2017 9:57 am
malcinator
(@malcinator)
It looks like the RepRapFullgraphics display. I have a similar one running on a Rambo Mini (not a Prusa MK2) running the RC8 Marlin Firmware. The biggest problem I found was the orientation of the two cables to the LCD display, I had to connect them the opposite way around on the Rambo Board.
You may have to edit these lines...
//#define ULTRA_LCD //general LCD support, also 16x2 <--------------Disable
#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) <--------------Enable
//#define REPRAP_DISCOUNT_SMART_CONTROLLER <--------------Disable
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER <--------------Enable
Make sure you install the U8glib in to your Arduino IDE and then upload the firmware. If all goes well it should work. There are some features that may or may not have been removed from the Prusa Marlin Firmware. Have a look in in the Configuration.h & Configuration.adv.h files. As far as I can tell the Prusa Configuration.h has been renamed to Configuration.prusa.h or something like that, I don't have the firmware to hand.
Publié : 14/03/2017 3:02 pm
pottedmeat7
(@pottedmeat7)
The only problem is I want to use the MK2 software with all the new enhancements, like the probe and centering
Publié : 14/03/2017 6:24 pm
malcinator
(@malcinator)
Sure, just edit the Prusa Marlin Firmware and upload it to the MK2 and you should be good to go. Check the LCD cable connections on the RAMBo as I mentioned.
Publié : 15/03/2017 12:21 am
