Problems with second layer and nexts
F Xavier Planta
(@f-xavier-planta)
Hi all
I'm a new user. I have a Prusa o3 MK2S , KIT.
I recently managed to get it going. It cost me a lot, especially the calibration of the PINDA
Now I have a problem, big problem. The first is that after the first layer,during the second or thirds layer, the plastic does not bond well and there are peaks, which collide with the nozzle and with the nozzle. The nozzle is often blocked with the plastic itself.
The other problem, random, is that depends on the first layer does not join the PEI .... clean it very well, no footprints or anything. .. is perfect and does not join.
The temperatures are correct...... grrrrrrrrrrrrrrrrrrrrrrrrr
I work with slicer3 and I have tried with the original gcodes, and with other designs of mine. MAterial is PLA.. I try with ABS.. the problem is the same. PLA is orignal prusa.
Can anybody help me?
I attach the photos .. HELP¡¡¡
Publié : 10/04/2017 9:08 pm
F Xavier Planta
(@f-xavier-planta)
Re: Problems with second layer and nexts
Please¡¡¡¡¡¡¡¡¡¡¡ any suggestions???????????
I'm crazy¡¡¡
Publié : 11/04/2017 8:09 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Print the Prusa logo from the SD card and upload pictures when that fails. It's a lot easier to diagnose problems when looking at a known model.
Peter
Publié : 11/04/2017 11:42 am
F Xavier Planta
(@f-xavier-planta)
SOLVED¡¡¡¡¡¡¡
The problem was the distande between , nozle and PINDA.... This is the most critical issues. Only 0,2mm was afected-
Depending your calibration XYZ and the PINDA sensitive.. the results will be good, better... ufff
Thanks a lot
Publié : 13/04/2017 12:02 pm
