Problem at the first start on every print.
Hello there. I have some problem with my Prusa i3 mk2S at every print the first Pinda checks failed on point 4!!!! If I reset the print It works perfect.
Some know this issue?
Best regards
Dennis
Re: Problem at the first start on every print.
You may want to try lowering the probe ever so slightly.
Also move Z up to the top end stops to ensure motor alignment.
Peter
There was no problem with the z axis. It moves in the bed every first print when I turn the printer on and start the first print. If I press reset and start the print again there was no problem.
Turn it off and on it goes again in the bed at point 4. Press reset and start print again the problem is gone.
But it's not good that the noozle goes in the bed every first print. I make a video and post it when I am back at home next week.
So here we go. Please take a look at this.
I make a video of my problem.
Someone a idea? I think it is a software problem?
doesn't the display tell you that the sensor is not triggered? dont know if i translated that right;)
so have you moved the pinda anything?
And after press reset it's all ok? I don't think so. The noozle was clean and the where nothing else. So I think there must be another problem.
The problem is reproducible. Always after starting the first print.
I was more thinking that the pinda stop finding the points on the bed i might be way of target though
Always at point 4? And after pressing reset it was over? And if I turn the printer off and on again the pinda didn't find the point 4?
There was another thread with the same problem.
Tbh, I had more-or-less the same problem and all I had to do was recalibrate Z.
Recalibrate doesn't fix the problem. I tried it often. But the problem was still there.
