Problems with my 1st print
martinberlin
(@martinberlin)
I just bought my Prusa i3 MK2s assembled, delivered yetserday.
Today I tried out my first print as described in the manuel. Unfortunately the outcome is not as expected.
The surface is not flat, but fluted:
At the test at the beginning the outcome is flat, but after some centimeters it get roundede:
For me as a beginner there are to many variables I could change, so I hope someone can give me a hint 🙂
Firmware: 3.0.10
Speed: 100
Flow: 100
Nozzle: 210
Bed: 55
Z: 150
Thanks
Martin
Opublikowany : 13/05/2017 9:05 pm
kevin.s5
(@kevin-s5)
Re: Problems with my 1st print
If you haven't found Jeff's excellent thread and instructions here then you should:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981.html
Using this method I found my printers sweet spot and it made all the difference being a newbie a few months ago.
Kevin
Opublikowany : 15/05/2017 5:50 am
martinberlin
(@martinberlin)
Thanks, very helpful ... Will have a deeper look at the Z variable ...
Opublikowany : 15/05/2017 3:29 pm
