problem with initial auto home calibration
revanth.y
(@revanth-y)
This is my time experience with any kind of 3d printer . I was done assembling my printer making sure every thing was right the first time around.
I was following the calibration procedure( STEP-3) , when i clicked the auto home, the nozzle ended up almost touching the print bed and tip ended up a lil to the outside of the print bed. (or might have just touched and made jamming noises ) at which point i was terrified by the noise and turned it off ( attached a picture of where it exactly stopped) . Once it returned to room temp i switched it on and used move axes to move it higher. Im stuck now and do not know how to calibrate my printer .
Here is what i thought was wrong:
1. The X end stop is positioned incorrectly( probably a lil loose) which resulted the tip going slightly out side the print bed, when it moved down in the Z.
To correct this if i moved the x end stop towards the center of heating bed by a few mm ( or tightening the end stop ),
but this would'nt solve the nozzle touching the print bed when it is coming down in the z direction ( even worse if i move the x end stop too much
it might pierce the glass).
Once thats solved and i get the home position right , how do i control the z direction manually in order to do the visiting card step ?( using move axes -from home position???)
2. Or do i lower my print bed( maintaining the 3 mm gap between the nuts as instructed)(section 7 ,head bed: step 11) , so that home position in z direction(nozzle tip) would'nt touch the print bed.
Really need some help , cant wait to start printing. not until this is sorted out though...
Thanks guys 🙂 🙄
Respondido : 20/01/2016 3:28 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: problem with initial auto home calibration
Hi there and welcome!
Easiest way to do this without damaging anything is to remove the glass and home the Z axis - use the "calibrate Z" option.
You then need to lower the aluminium Y carriage using the screws at the 4 corners until you can slide the glass sheet under the nozzle.
Clip the glass in place, do a preheat and then adjust the 4 screws again until the card just slips between nozzle and glass in all 4 corners.
Peter
Respondido : 20/01/2016 3:57 pm
revanth.y
(@revanth-y)
Thanks for your help. I couldn't work on the printer all these days due to a knee surgery. I just started working on it again. I followed what you said, but at the lowest position of the print bed, there is not enough room to place the glass. I could home the printer with out the glass. What can I do now ??? Have attached a couple of pictures for reference as well. Thank you.
Respondido : 23/06/2016 10:15 am
PJR
 PJR
(@pjr)
Sorry to hear of your problems; I trust you are now in good health?
OK, so there a couple of things you can check or a much simpler work-around for the problem. Personally I would look for a fix, because there is obviously something wrong somewhere...
I do like to have the X axis homing just slightly left of the glass, just in case...
But first the work-around:
The Z endstop is too low; loosen the screws, try to raise and tighten the screws. Then lift the Z endstop holder upwards; put something underneath it so it can't work its way downwards.
Now, the fix.
Either the Z endstop it too low or the Y chassis is too high.
Check that the 3 bearings are properly located in the slots of the Y frame and that the Y frame is fully home in the slots of the Z frame (the nuts on the 12mm threaded rod). The Z frame should not touch the table top, only the feet at the corners of the Y frame.
Make sure the Y smooth rods are properly hime in the corner posts.
Here's a picture so you can see how the adjustment should be:
Peter
Respondido : 23/06/2016 11:37 am
christophe.p
(@christophe-p)
Miembro Moderator
Hi revanth,
I believe too that the Z-frame is positioned too low.
In addition to what Peter described, I used a little trick to do that: After removing the pad under each corners, in order to be sure that the Y bed is flat square on the table, I used a small pile of some business cards under both side of the Z-frame before unscrewing a bit the 12mm nuts. Make sure the Z-4 corners are touching evenly the table and tigthen again M12 bolts.
That way, you'll ensure the Z-frame is well positioned. If it's not enough, repeat this with more business cards.
I'm like Jon Snow, I know nothing.
Respondido : 23/06/2016 7:23 pm
