Problem with Bed temperature Sensor
christian.s8
(@christian-s8)
Hi guys,
Here is my Problem with my bed temperature sensor:
Bed is heating up but it is not recognized by the sensor. It sticks with 27-30 / 60 °. I tried selftest and checked cable.
What could it be? Many thanks in advance! Furthermore I had this problem once before, but it comes back regularly without clear reason... 🙄
Cheers
Chris
Napsal : 06/04/2017 3:09 am
JeffJordan
(@jeffjordan)
Member Moderator
Re: Problem with Bed temperature Sensor
simply check if the temperature sensor, which is fixed with kapton tape underneath the heatbed, has proper thermal contact to the heated surface.
sometimes it is badly assembled.
if it is ok, then check if the heatbed still heats up (infrared thermometer might be more reliable than checking it with your fingers).
maybe the sensor is ok but the fuse for the heated bed is blown. btw: does the led at the rear of the heatbed, where the connector is located, still lights up when trying to heat ?
Napsal : 06/04/2017 1:47 pm
christian.s8
(@christian-s8)
Thanks for your reply. Nothing worked so far, so I contacted the support chat and they ran my through some test and wanted to see some pictures. After that they decided that I get an replacement of the temperature sensor.
Good service!
Napsal : 07/04/2017 8:32 am
JeffJordan
(@jeffjordan)
Member Moderator
yeah, sometimes such a part is simply defective...
Napsal : 07/04/2017 12:08 pm
