[Problem] Left Front calibration point not Reachable
Hi ! I have a little problem with my Prusa I3 MK2 Kit, Z calibration is fine, but XYZ calibration is not, while "Checking height..." it display : "Left Front calibration point not reachable". I found something, and i wan't to know if it's a problem or completely normal, here i made a picture in photoshop of a Bed with his calibration point, and you can see what zone the probe can access or not :
I checked everything, if the threaded rods are perpendicular to the Z axis...
I don't know what to do 🙁
Here is some pictures about the probe above the calibrations points, and the Bed axis is at max position (Because you can here the click from switch) :
If you wan't more info, tell me please 🙂
I really wan't to print 😥
Re: [Problem] Left Front calibration point not Reachable
Hi! Your printer should be fine as long as it is able to pass the XYZ Calibration without any major errors and the left front error isn't a bad one at all. 😀 In the 3d Printing guide that Prusa gives you it says that the Left Front isn't a big deal. I got the same thing along with a X and Y axis error and I was able to print same day. So i would worry too much. If you encounter more issues feel free to ask! 🙂
