Printing problem with y-axis
kafi
 kafi
(@kafi)
After my first print (Marvin) , i test successfully a second small object.
Now i would print al larger object, ca. 100x60 mm, a building with seperate roof. I load the object with sli3er and export as gcode file with correct pla and printer. But with greater obejct it hink the printer has a problem with the x-axis, after print some layers, see photos.
What can i do? 😯 Have anybody an idea?
Napsal : 19/07/2016 10:24 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Printing problem with y-axis
Try printing in high power mode.
Peter
Napsal : 19/07/2016 11:17 pm
