Printer only works when plugged into a laptop/computer
wills.w
(@wills-w)
Hello
I've been using my printer for the last year or so without any problems but when I was doing a print the printer just stopped midway through a print, the display was off along with all the other components, but the power supply was still running. So I thought I'd plug my laptop in and the printer to my disbelieve started to work but as soon as I unplugged the laptop from the printer using the usb port it would stop working and I would go back to stage one.
Any help guys?
Opublikowany : 05/01/2018 12:31 am
Olef
 Olef
(@olef)
Re: Printer only works when plugged into a laptop/computer
Sounds like your Rambo might have a power problem and it only powers up from the USB when connected?
Opublikowany : 05/01/2018 11:33 am
Dewey79
(@dewey79)
Does the display still work or could that have gone out? I've read other posts regarding tight wire runs chafing to the point of wires breaking or just becoming unplugged.
One person found the issue was a broken wire by using a multimeter.
Opublikowany : 05/01/2018 2:22 pm
wills.w
(@wills-w)
Yeah as soon as the usb is disconnected the screen stops working.
Opublikowany : 05/01/2018 5:40 pm
wills.w
(@wills-w)
The display works but only when the usb is plugged in.
Opublikowany : 05/01/2018 5:41 pm
